VLAN and etherchannel on Catalyst & Linksys switches. Compatible ?
Sep 29th, 2008
Is it possible to configure both Catalyst and Linksys switch to work together for VLAN and Etherchannel ? If yes, can you give me the resources which I can refer to ?
Thanks very much.
Daniel Alex
Overall Rating: 3 (1 ratings)
alexals Mon, 09/29/2008 - 17:07
Hi Andrew,
Cisco CAT4507R (WS-C4507R) and Linksys 48-port 10/100/1000 Switch + 4 shared mini-GBIC Ports (SRW2048P)
Thanks & regards
Daniel
glen.grant Mon, 09/29/2008 - 17:23
  • Purple, 4500 points or more
Yes it should , looking at the stat sheet for the linksys says it supoorts lacp so you should be able to etherchannel ports together as the 4506 supports lacp also .
