IP FLOW EGRESS - Cisco 6506's??
Sep 29th, 2008
Hi Guru's!
We have a Cisco 6506 and we have IP NetFlow configured on the LAN/WAN interfaces (both are gigbitethernet ports). We have "ip flow ingress" on the LAN interface which is sending the stats back to our server.
However if we configure "ip flow egress" on the WAN port, it stops sending the stats back to our server completely. Is there a hardware issue on the 6506's related to NetFlow? Or a bug? I've done a bug search on the platform and there is nothing obvious related to what we are seeing.
We know it's not our configuration because we have a duplicate configuraion on a Cisco 6524 and that one has no issues and is sending the stats to our server with no issues.
This is the IOS we are using:
bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXH.bin
The version we're using is:
ip flow-export version 5
aa_mohammed Sat, 10/04/2008 - 02:42
This is resolved.
More importantly Cisco said (TAC) that the egress command is redundant.
Thanks for your mail. Yes, removing 'ip flow egress' should not make any
difference for hardware switched flows. There is a difference in NetFlow
configuration since 12.2(33)SXH IOS and later - now 'ip flow ingress' is
required (and enabled by default when you configure NetFlow globally) as
we can now do interface specific NetFlow. In the past there was no way
to collect PFC switched flows for a subset of interfaces.
Is my understanding correct that all flows are now exported as expected,
but missing the TOS field?
If you check 'sh mls netflow ip detail nowrap', do you see any non-zero
values logged under the QoS field?
Another email:
Unfortunately, egress NetFlow is not supported in hardware on any PFC3*
system - only software switched flows will be collected by this
configuration. Equally, 'ip flow ingress' only applies for software
switched flows. By default, all hardware switched flows will be
collected on the PFC - you can verify this with 'sh mls netflow ip'.
