OSPF Advertisement
Sep 29th, 2008
Hello All,
Can someone please help clarify the difference between:
network area xx
network area xx
When advertising networks in OSPF?
Many thanks in Advance
Overall Rating: 4 (3 ratings)
Marwan ALshawi Mon, 09/29/2008 - 03:22
in the network field 0 mean any
in the wildcard field 255 means any
if helpful Rate
newnetman Mon, 09/29/2008 - 05:08
If in the wildcard field 255 means any, What would the following mean then?,
network area xx
because i am still confused if in the wildcard field means "specificity", what would it then care about in the network field with
Marwan ALshawi Mon, 09/29/2008 - 05:13
the mask in wild card mean host
if u wanna advertise host u give it this wildcard
ariesc_33 Mon, 09/29/2008 - 23:38
this is actually confusing. i cant find any documentation so the best way to verify this is on a lab or actual scenario. if you encountered this on the actual network, then you definitely have a clue by using show ospf commands and see what is being advertise by the router.
Danilo Dy Tue, 09/30/2008 - 03:22
I'm not sure about this, but I think if you type the following....
router ospf
network area xx
....it will show in the "show run" as;
router ospf
network area xx
Edison Ortiz Tue, 09/30/2008 - 07:32
The IOS will change the command
network area xx
network area xx
As the first command isn't valid. The subnet portion will determine what to match from the network portion. If the network portion is all 0s, there is nothing to match so the correct subnet mask is 255 (don't care bits).
