ASA DHCP Relay Feature
Sep 29th, 2008
I'm trying to remove the DHCP services from the ASA, thus I also need to enable the DHCP relay server feature. Do I have to disable the DHCPD config also for the management interface?
Thanks.
Overall Rating: 4 (2 ratings)
Marwan ALshawi Mon, 09/29/2008 - 03:28
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
the following example will help u under stand the requiremnt
DHCP Relay Example
A DHCP relay is configured to accept DHCP requests from clients on the inside interface and
relay them to the DHCP server at 192.168.1.1 on the DMZ interface. The firewall waits 120
seconds for a reply from the DHCP server. The firewall's inside interface address is given to the
clients as a default gateway. You can use the following commands to accomplish this:
Firewall(config)# dhcprelay server 192.168.1.1 dmz
Firewall(config)# dhcprelay timeout 120
Firewall(config)# dhcprelay setroute inside
Firewall(config)# dhcprelay enable inside
if helpful Rate
jonix.niebla Mon, 09/29/2008 - 03:46
Thank you. One more thing though, is it possible to have dhcprelay and dhcpd configuration active on your ASA?
Thanks again.
Marwan ALshawi Mon, 09/29/2008 - 03:48
u can but they shoud operate in diffrent interfaces
if helpful rate
good luck
suschoud Mon, 09/29/2008 - 05:27
  • Gold, 750 points or more
Unfortunately this is not possible.I am not sure why you were told yes by marva :
ASA5510-Single(config)# sh ip
System IP Addresses:
Interface Name IP address Subnet mask Method
Ethernet0/1 inside 192.168.16.9 255.255.255.128 CONFIG
Management0/0.2 newsubnet 10.10.0.7 255.255.255.224 CONFIG
Current IP Addresses:
ASA5510-Single(config)# dhcprelay server 192.168.1.1 newsubnet
ASA5510-Single(config)# dhcprelay timeout 120
ASA5510-Single(config)# dhcprelay setroute inside
ASA5510-Single(config)# dhcprelay enable inside
ASA5510-Single(config)# dhcpd ena
ASA5510-Single(config)# dhcpd enable inside
DHCP: Interface 'inside' is currently configured as RELAY SERVER and cannot be c hanged to a SERVER by a SERVER feature
ASA5510-Single(config)# dhcpd enable newsubnet
DHCP: Interface 'newsubnet' is currently configured as RELAY and cannot be chang ed to a SERVER by a SERVER feature
Sushil
Marwan ALshawi Mon, 09/29/2008 - 05:32
i said they should operate in diffrent interfaces
if hte relay is on the inside u may use the firewall as dhcp server for the dmz network
ofcourse u cant use the same interface as both
relay trnslate the broadcast to unicast for the dhcp server and dhcp server anser for client request
suschoud Mon, 09/29/2008 - 06:02
in the above example,I tried setting dhcpd on both the interfaces,dmz ( newsubnet in my example ) and inside.None of that works.I know there is a documentation error or cco.But it never worked for me.....tested this a lot during my ccie prep. :)
Sushil
Marwan ALshawi Mon, 09/29/2008 - 06:01
Suhil
thefollowing config example i have just done it
interface inside firewall as dhcp server
dmz is dhcprelay to a server on dmz1
dhcpd address 192.168.1.1-192.168.1.10 inside
dhcprelay server 10.1.1.1 dmz1
dhcprelay enable dmz
dhcprelay timeout 60
but U were right !!
pixfirewall(config)# dhcpd enable inside
Can't start DHCP daemon - DHCP Relay Agent is running.
logicaly sounds ok but practicly not
thanks for pointing me out
suschoud Mon, 09/29/2008 - 06:04
Sir,
Please enable the dhcp server on inside.By just defining a scope does not enable dhcp server on inside.
Try adding :
dhcpd enable inside
You would know what I am saying...
Sushil
Marwan ALshawi Mon, 09/29/2008 - 06:07
it sounds we overlaping in the posts i changed the post read the one above again
and i rated u as well :)
thansk
suschoud Mon, 09/29/2008 - 06:06
Great,
Glad to share.Have a nice one.
Sushil
