dhcpd configuration
Sep 29th, 2008
I have the following dhcpd configuration:
dhcpd address outside
dhcpd enable outside
When I do
show proc | inc dhcp ,
I see the process, so it seems to be active. But when the client sends requests they droped on the outside interface with message:
%PIX-7-710005: UDP request discarded from to outside:
I searched on web, and seems this error means the device is not listening on this port. It was suggested to reboot the deamon, which I did, but I still get the same error. Any idea what to do?
sansari Mon, 09/29/2008 - 09:13
I added something similar, and I'll try this also. Here is what I have right now:
access-list inside-acl extended permit ip any any
access-list inside-acl extended permit udp any any
To give you little more information. Seems the dhcp server configuration on this device works fine. The issue is with dhcprelay packets coming from another device between my client and the server. Here is what I amtyring to set up:
When I configure the outside interface of pix1 with
ip address dhcp, it seems to get an ip address from the server just fine. But when the request comes in the form of a unicast udp packet through a relay vs. a multicast packet, the dhcpserver(pix2) drops the packet. Not sure why ...
sansari Wed, 10/08/2008 - 04:02
I am doing some captures and see the service seems to work. Except that the device which is doing relay drops the udp packet from my dhcp server on its outside interface. Here is the message I see in the logs:
Here is the relevant config from the dhcprelay device:
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
ip address
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 25
ip address
access-list outside-acl extended permit ip any any
dhcprelay server outside
dhcprelay enable inside
dhcprelay setroute inside
dhcprelay timeout 90
sansari Wed, 10/08/2008 - 04:41
One more item to add, this packet drop shows up in the aspdrop capture also. Any thoughts on why?
sansari Wed, 10/08/2008 - 06:50
Just to share the result with other folks, so you do not run into this issue, or know a possible way out. Seems I was running into an undocumented bug with 7.2(1) or rather one that was not seen before. 7.2(4) however is working fine. Thank you all for your comments.
