WAE 7326 - interface standby vs active-active configuration
Sep 29th, 2008
i am configuring two WAE 7326 in our network eenvironment as cache in proxy mode. it is to be connected to a switch just before the firewall.
while configuring i came accross two types of interface configurations active-standby and active-active. which one is prferable and what is the best practice for interface configuration and disk space allocation?
Thank You and Kind Regards,
drolemc Fri, 10/03/2008 - 10:57
Active/Active Failover and Active/Standby Failover. Each failover configuration has its own method to determine and perform failover. With Active/Active Failover, both units can pass network traffic. This lets you configure load balancing on your network. Active/Active Failover is only available on units that run in multiple context mode. With Active/Standby Failover, only one unit passes traffic while the other unit waits in a standby state. Active/Standby Failover is available on units that run in either single or multiple context mode. Both failover configurations support stateful or stateless (regular) failover.
For further information click this link.
