Route Plan
jamesfang98 Mon, 09/29/2008 - 07:23
Yes, you can use SQL query to create customized query to pull reports - first of all you need to understand CCM DB schema and its tables fields, then build your own SQL query script for your own report, like: RP/Partition/CSS/Translated-Mask/GW...
Pls rate if help
