Beginner Access control Lists
Sep 29th, 2008
I have a 6509 with a router module installed. On this router I have multiple vlan interfaces one for each subnet. I am adding a new subnet which I want to isolate except for outbound Internet access and specified functions between the subnets.
the subnets are which is the gateway to the internet, and I want to add
All of these have an interface on the router of 1 as the last octet. I have written the following access lists
deny ip
deny ip
deny ip
permit ip any any
permit ip eq telnet
Will these access lists do what I need and which should be applied outbound and which should be applied inbound
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 09/29/2008 - 09:02
Hello Ron,
I would suggest you to use only one ACL.
first the permitted communication between local subnets
access-list 105 permit tcp eq telnet
! note the position of the TCP port you want to have telnet access to devices in from
! then you deny all other internal communication
access-list 105 deny ip
! then you permit internet access
access-list 105 permit ip any
! in this way you have also anti-spoofing you don't allow a source non in to go out
I would apply this ACL inbound on SVI Vlan with ip address
let's suppose it is vlan 10:
int vlan 10
ip access-group 105 in
Hope to help
