call routing base on changing param in H323 router
Sep 29th, 2008
Hi, I need to build a solution using an existing 2811 h323 voice router, to route call diffently each hour.
An internal system can update someting on the router (a param or a file) and the router has to read that information and then route the call base on that info. Do you have any conf example for me ? a tcl ?
1am: DID = 514-555-1212 -> reroute = 613-342-2323
2am: DID = 514-555-1212 -> reroute = 819-331-2623
3am: DID = 514-555-1212 -> reroute = 456-144-1323
IAN PERRY Tue, 09/30/2008 - 00:42
There are sample TCL scripts that will do time of day routing.
Download from http://www.cisco.com/cgi-bin/dev_support/access_level/product_support
You can download a ZIP file with the TCL script and a document explaining how to implement this on your gateway.
This script adds a prefix to a called number based on ToD rules, so you may need to add in some translation patterns to acheive your desired result.
francis.labelle... Tue, 09/30/2008 - 11:56
Humm, I'm looking for a tcl script that can read a txt file (located on the router flash). That file will contain the info about where transfer the call..
i.e. 533-555-1212 => 123-123-1234
533-555-1213 => 332-134-3434
533-555-1214 => 132-366-9999
That file will be loaded on the router each hour (worst case screnario)
Thanks !
