Reassembly limit exceeded
Answered Question
Hi, wonder if anyone could help with this issue... we have recently upgraded to version 8 from version 6 on PIX
When connected to Oracle servers over a VPN tunnel it bombs out with errors, looking on the PIX log (attached) showed a reassembly limit is exceeded. I've looked on the web and found a work around is to remove 'inspect rstp'
i have done this but the errors persists
It did'nt happen on version 6.3 any ideas?
Correct Answer by suschoud about 8 years 7 months ago
Please remove " inspect sqlnet " too.
Do rate if it resolves the issue.
Sushil
Overall Rating: 5 (2 ratings)
jjohnston1127 Mon, 09/29/2008 - 07:14
  • Silver, 250 points or more
Please provide a running configuration of your device also.
You can try this command:
set connection embryonic-conn-max 16384
Correct Answer
suschoud Mon, 09/29/2008 - 07:17
  • Gold, 750 points or more
Sushil
abinjola Mon, 09/29/2008 - 08:12
  • Cisco Employee,
Jmoss..removing Inspect wont help..you are getting reassembly limit exceeded error because tcp-proxy function/Inspection is enabled..and as TCP Proxy is mandatory for certain inspected protocols SIP, Skinny, H.323,RTSP disabling it wont help...
your problem is this CSCsl15229
Rate if this was helpful...
abinjola Mon, 09/29/2008 - 08:13
  • Cisco Employee,
abinjola Mon, 09/29/2008 - 20:49
  • Cisco Employee,
this was a feature enhancement request...you may go to any of these codes..
8.0(4.1)
8.2(0.141)
8.1(101.6)
8.1(1.10
plz rate if it helps !
