Cisco 1861 ISR: snmpwalk timeout on sysObjectID MIB variable
Answered Question
Sep 29th, 2008
Hi folks!
I'm doing a snmpwalk query on a Cisco 1861 ISR.
I'quering the following MIB variables:
C:\>snmpwalk -v2c -c public 88.63.17.142 sysdescr
SNMPv2-MIB::sysDescr.0 = STRING: Cisco IOS Software, C1861 Software (C1861-ADVIP SERVICESK9-M), Version 12.4(11)XW5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 17-Nov-07 05:31 by prod_rel_team
C:\>snmpwalk -v2c -c public 88.63.17.142 sysObjectID
Timeout: No Response from 88.63.17.142
The sysObjectID goes in timeout.
What kind of problem I'm hitting?
Any ehlps would be appreciate.
Thanks a lot
Leonardo
Correct Answer by Joe Clarke about 8 years 8 months ago
Most likely. This code looks to be the same code that ships with the router. You should probably move to a 12.4T release (e.g. 12.4(15)T). You may be seeing a stack trace on the router's console when you poll for sysObjectID. If so, that would be helpful.
Overall Rating: 4 (2 ratings)
Joe Clarke Mon, 09/29/2008 - 08:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The syntax looks fine. What other objects time out? Is it just sysObjectID, or are there others? Does sysObjectID always time out? If possible, enable "debug snmp packet", repeat the problem, and post the output.
leorob123 Tue, 09/30/2008 - 00:15
yes Joe,
the only MIB variable timeout is sysObjectID.
Is it possible a IOS bug?
I will enable debug as you suggest.
Leonardo
Correct Answer
Joe Clarke Tue, 09/30/2008 - 06:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
