MTP Sessions on CUBE
Sep 29th, 2008
I have to configure a Cisco 2821 as MTP in the CallManager. How many sessions does a Cisco2821 with PVDM-2-32 onboard support in hardware and software? The Router is running 12.4(20)T.
Peter
jsivulka Fri, 10/03/2008 - 08:03
  • Bronze, 100 points or more
The resources number is related with the service parameter of the IP Voice Media Streaming App "call count" in the MTP parameters. This service parameter is located in Service -> Service Parameters -> Cisco IP Voice Media Streaming App
This parameter specifies the maximum number of calls that the mediatermination point will support. By default its value is 48 that stands for 1 MTP resource = 2 streams which means the default number of MTP resources available is 24.
So to have 48 MTP resources you need to increment the call count to 96.
Increasing this value above the recommended default may cause performance degradation on a Cisco CallManager that is running on the same server, the exact number of MTP resources that are available depends on the amount of resources that is being consumed by other applications on that PC.
Stoyan Stoitsev Sat, 10/04/2008 - 05:15
You can check the DSP calculator on the Tools section in CCO.
Or try this doc
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/voice/cminterop/configuration/guide/vc_enh_confr_vgr_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1012833
Btw, try moving your post to the IP Telephony section of the forum ;)
Best regards,
Stoyan Stoitsev
