Cisco CME with Cell Phones
Sep 29th, 2008
Please can someone tell me wich models of cell phones are Compatible with cisco call manager? i know that some models of Nokia Eseries are, but wich ones? and what about blackberry? and other models? Can i find some information about this on Cisco web page? please help me. Thanks very much
Overall Rating: 5 (2 ratings)
Rob Huffman Mon, 09/29/2008 - 08:33
Hi Joao,
There are various Nokia E Series Models currently supported in the attached links;
Supported Nokia mobile devices:
Nokia E51
Nokia E60 (PR3)
Nokia E61 (PR3)
Nokia E61i
Nokia E65
Nokia client software:
Cisco Unified Communications
Manager 6.x
Manager 5.x
Manager 4.2
Manager 4.1x
Manager Express 4.1
500 Series for Small Business
From this good Nokia doc;
http://europe.nokia.com/NOKIA_BUSINESS_26/Europe/Products/Mobile_Software/Cisco_CallManager/cisco_datasheet.pdf
The support docs and software can be found here;
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
Hope this helps!
Rob
joao.mendes Mon, 09/29/2008 - 09:10
Thanks for your help:) by the way, you know if there are other brand with cell phones compatible for Cisco CME? wich one? thanks one more time!
Rob Huffman Mon, 09/29/2008 - 09:22
Hi Joao,
Only Nokia so far :) I do know that Cisco is working with RIM towards support for the Blackberry, but it has not achieved this status as of yet.
Hope this helps!
Rob
fahadrazi Wed, 01/07/2009 - 00:28
Dear Joao,
I have Call manager 5.1... and i also want to add Nokia phones there. but the issue is in Devcie > phones > add new... i am not able to find nokia series name there to add.. can you please tell me how i update the devcie list ?
Thanks in advance
Wating for your reply...
dezoconnor Wed, 01/07/2009 - 03:26
Hi Fahad, I believe the process is to add them as 7960's or 70's.
Click “Add a new phone” and enter MAC address (*#62209526#) and description
• Select “Line 1” under the Directory Numbers section
• Enter VoIP extension number in Cisco CallManager directory
fahadrazi Wed, 01/07/2009 - 03:30
Thanks for your reply.
I completed the ccm part now want to know how i configure my nokia phone ?
