Cisco ACE license question
Sep 29th, 2008
If a license is not installed on ACE how does the ace work? I mean the license should have a feature set? or is the license needed to do additional feature set? when I do show license I get a message no feature license installed
see below
Software
loader: Version 12.2[120]
system: Version 3.0(0)A1(4a) [build 3.0(0)A1(4a) adbuild_20:11:06-2007/02/0
6_/auto/adbu-rel/ws/REL_3_0_0_A1_4A]
system image file: [LCP] disk0:c6ace-t1k9-mz.3.0.0_A1_4a.bin
installed license: no feature license is installed
Hardware
Cisco ACE (slot: 1)
cpu info:
number of cpu(s): 2
cpu type: SiByte
cpu: 0, model: SiByte SB1 V0.2, speed: 700 MHz
Syed Iftekhar Ahmed Mon, 09/29/2008 - 09:37
Ace is shipped with a default license installed. (4GB badwidth, 1k ssl transcations/sec & 5 virtual contexts).
You can see the license using following command.
ACE/Admin# show license status
Licensed Feature Count
SSL transactions per second 1000
Virtualized contexts 5
Module bandwidth in Gbps 4
If you want to increase contexts/throughput/SSL transactions then you will need to buy additional licenses.
For example for additional SSL transactions/sec
ACE-SSL-XXK-K9 (where XX could be 05/10/15/20)
Or For Additional Virtual Contexts
ACE-VIRT-XXX (where xxx represent no of contexts and options are 20,50,100,250)
Syed
