Vista 64bit VPN client support
Sep 29th, 2008
I have read that currently Cisco VPN Client does not support Vista 64bit OS, and that AnyConnect does. I have a WinXP laptop which I have Cisco VPN Client installed with MANY (about 50) *.pcf profiles installed. I loaded AnyConnect on my new Vista 64bit desktop, and expected to load the same *.pcf profiles. But apparently AnyConnect uses XML profiles which I do not fully understand. Is there a simple solution to configuring my AnyConnect using these pcf profiles, which comprise host address, group authentication, and username/pwd? Or, is there a solution so I can use Cisco VPN Client on my Vista 64bit desktop?
thomuff Wed, 01/21/2009 - 11:48
did you figure out migrating the pcf files to the xml files.
Phillip Remaker Fri, 02/19/2010 - 11:29
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
