enabling CEF changing connected routes to static route
I have 3800 router which has ospf for LAN and static. we are redistributing static routes into ospf. when enabling local gig interface which was showing connected become static route. we routing local subnet also to serial interfaces. but local interface should be showing connected. Please provide me a solution on this.
Overall Rating: 3 (1 ratings)
Harold Ritter Mon, 09/29/2008 - 17:35
Could you please provide the output of a "show ip route x.x.x.x" for the specific route and "show int xx" for the specific int.
Router2#sh ip route
Routing entry for
Known via "static", distance 1, metric 0
Redistributing via ospf 1
Advertised by ospf 1 subnets
Routing Descriptor Blocks:
Route metric is 0, traffic share count is 1
We have route to
statis routes redistributed into ospf. It usually shows connected when no ip cef. When CEF enabled showing static.
ariesc_33 Tue, 09/30/2008 - 00:25
i think has something to do with the way that CEF maintains the FIB database, cant explain further though.
on the neighbor routers with CEF enabled,do you see the same route as ospf route?
Harold Ritter Tue, 09/30/2008 - 05:01
Can you provide the exact configuration of the static route and the version of IOS you use.
interface GigabitEthernet0/0
ip address
no ip redirects
no ip proxy-arp
ip nat inside
ip virtual-reassembly
no ip mroute-cache
ip ospf authentication message-digest
ip ospf authentication-key
duplex auto
speed auto
media-type rj45
no cdp enable
router ospf 1
redistribute static subnets
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
ip route (customer FW)
ip route
IOS version : c3845-advsecurityk9-mz.124-15.XY1.bin
OSPF used in LAN environment for redundancy.
