WCCP GRE Redirection multiple hops
Sep 29th, 2008
When using GRE redirection and negotiated return, is it possible to place the WAEs on a segment that is not directly attached to the routers? I have seen some documentation state, "It allows the WCCP clients to be separate from the router via multiple hops. With WAAS, the WAEs need to be connected directly to a tertiary or sub-interface of the router." This has left me a little confused, but seems like it is possible with new code. If it is possible, is there any possibility on looping occuring? I assume there isn't since the packets are tunneled to and from the routers which would bypass the inspection. This would also allow me to take advantage of WAAS over a high-speed/low latency link to a datacenter that does not physically have WAEs deployed.
Any input is much appreciated,
dstolt Mon, 09/29/2008 - 17:09
You are correct, the WAE with negotiated return can be multiple L3 hops away from the router (back in your DC). However for performance, of course it's recommended to be as close as possible. With the return traffic using GRE, the traffic is not being re-intercepted.
