spanning-tree portfast trunk to HP virtual connect
Answered Question
Sep 29th, 2008
We are implimenting etherchannles from the HP virtual connect to our swithces.
HP's suggested config is the following
Interface port-channel 1
swithport trunk encapsulaiton dot1q
switchport trunk allowed vlan 3,4,5
switchport mode trunk
spanning-tree port-fast trunk
interface gig0/1
Does spanning-tree portfast trunk seem correct?
What would be the benefit of this?
Correct Answer by Jon Marshall about 8 years 6 months ago
Certainly can. A lot of NIC's on servers these days are capable of running 802.1q.
Jon
Overall Rating: 3.3 (3 ratings)
Jon Marshall Mon, 09/29/2008 - 10:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The benefit of this is that even though it is a trunk link it will still act as a portfast access port and not have to wait the full 50 seconds of listening/learning/forwarding.
The command is there specifically for end servers that are connected to the switch via a trunk link.
Jon
Mohamed Sobair Mon, 09/29/2008 - 10:08
  • Gold, 750 points or more
OH ... Long time not see ,
Never set spanning-tree portfast on a trunk ports.. This could result in spanning tree loops , Portfast has to be set on access port where there are host connected not bridges.
Mohamed
Jon Marshall Mon, 09/29/2008 - 10:11
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mohamed
Think that's the point. I agree it should never be set on uplinks to switches but it isn't in this case.
Jon
nygenxny123 Mon, 09/29/2008 - 10:46
I guess I learned that things other than switches can perform "trunking"
Correct Answer
Jon Marshall Mon, 09/29/2008 - 10:53
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
louis-philippe.lison Thu, 11/04/2010 - 05:55
Hi there!
Would you recommend to add "BPUDguard" along with porftast on the trunk in order to put the port in error-disabled state in case of BPDU received on the trunk?
LLP
Bert Gevers Thu, 11/04/2010 - 06:52
  • Cisco Employee,
Basically,BPDU guard runs on ports which are configured with portfast and therefore, connect to end devices.
As these end devices never originate BPDUs, you should indeed configure BPDU guard to prevent spanning-tree loops
caused by miscabling/...
You can read up on BPDU guard at the following link:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
