09-29-2008 09:07 AM - last edited on 03-25-2019 03:20 PM by ciscomoderator
Greetings, i have a BT NTU installed at one of customer sites which presents the circuit on G.703 120ohm, im looking for appropriate baluns to connect between a Cisco 2801 over Ethernet and the NTU itself.
Could someone clarify if the products below would be suitable, picture of NTU attached. I believe the connectors on the NTU are Male BNC.
G.703 Balun 2.048-Mbps, Female
http://www.blackbox.co.uk/solutions/display.asp?cs=dvh&id=1&doc=mt242a-m
Duplex G.703 Coax Cable (Siamese), 3.0-m
Solved! Go to Solution.
09-29-2008 10:08 AM
Hello Mark,
balun are fine to connect the g.703 to an RJ-45 E1 port not ethernet port.
You need a straigh through ethernet cable with all pairs cabled to connect the E1 port to the balun RJ-45 port the two coax are connected to their connectors.
And you need two coax cables to connect the balun to the NTU.
E1 port is a serial interface not ethernet.
your choices look like correct but you need an E1 port.
Hope to help
Giuseppe
09-29-2008 10:08 AM
Hello Mark,
Hope to help
Giuseppe
09-29-2008 12:37 PM
Thank you very much for your time, the response is most helpful.
