WCS Background Tasks for Configuration Backup
Sep 29th, 2008
Hey,
I have WCS v5.1.64.0 and I have started to do a Configuration Backup of my WLC 4402's but I'm getting the following errors:
com.cisco.server.common.errors.IllegalOperationException: MEDIATION-5,TransferConfig!10.10.1.6,saveConfigStart,No access
Have any one seen this error before? Can any one assist with this?
sbilgi Fri, 10/03/2008 - 09:04
  • Silver, 250 points or more
To find out where the configuration backup job will be saving the backed up configurations, you can check the following files:
In C:\program files\wcs4.1\webnms\ftp-server\conf\ftpd.conf file the first line has the ftp default directory.
In C:\programfiles\wcs4.1\webnms\classes\com\cisco\packaging\packagingresources.prope rties, the tftproot option has the default tftp directory.
The file will be saved in a format such as __<#>.cfg and will have an xml format. You can directly restore these config files back to the controller if needed.
edward.weir Fri, 10/03/2008 - 09:33
Thanks for the reply but these are the settings that are already in place:
FTP:
FtpServer.server.config.root.dir=C:/WCS/FTP
TFTP:
TftpRoot=C:/WCS/TFTP
My issue seems to be an SNMP error:
edward.weir Mon, 10/20/2008 - 07:21
I actually got this working due to a simple error. I entered the ReadOnly SNMP String instead of the Read/Write SNMP String.
Trending Topics - Security & Network
