09-29-2008 10:14 AM - edited 03-18-2019 09:43 PM
We are currently moving to citrix agent desktops, which will be on a different vlan from the phones. If we do this will i need to add SPAN to the switching network, and enable the second NIC in the IPCC server to continue doing callrecording. Will I have to rerun setup from the IPCC CD, or just the post-install?
09-29-2008 04:25 PM
bump
09-30-2008 05:13 AM
also, The switches are cored to a 4507, with 3560's at the edge.
10-03-2008 04:04 AM
Yes you will need to do SPAN-based monitoring/recording using the second NIC of the UCCX server. Be advised that you can not have a layer three boundry between the phones and the UCCX server for SPAN-based recording as the built-in recording service looks for the appropriate RTP stream based on the agent phone's MAC address (which is overwritten by a router).
You do not need to reinstall.
Here is the Cisco documentation relevant to what you are seeking to do:
Cisco CAD Installation Guide 6.4 for Unified CM: http://cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_5_02/installation/guide/cad64ig-cm.pdf
Cisco CRS Installation Guide 5.0(2): http://cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_5_02/installation/guide/crs502ig.pdf
Integrating CAD Into a Citrix MetaFrame Presentation Server or Microsoft Terminal Services Environment: www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/cad_enterprise/cadenterprise7_2/installation/guide/CADCitrixMTS.pdf
10-03-2008 05:13 AM
Do i need to re-run anything to enable the second network card for monitoring?
