Cisco rtr AUX <--> USR modem: where am I doing mistake
Sep 29th, 2008
  • Gold, 750 points or more
Hi All,
Trying to configure a USR 56K modem to 2801 AUX port.
rtr:
line aux 0
session-timeout 20
login local
modem InOut
modem autoconfigure type usr_courier
transport input all
speed 115200
flowcontrol hardware
--> Modem initialised using rtr Lo0 ip
telnet 10.250.222.10 2001
at
OK
at&F1S0=1
OK
at&w
OK
--> here I am unable disconnect reverse telnet session using ctrl+shift+6+x. So I rebooted all and tried to connect to phone line, no response from modem when dialing. LEDS AA/DTR/MR/RTS/CTS are lit.
only DIP switches 3&8 are DOWN.
While connected to phone line, I ran at commands successfully, but still unable to dial. The phone line is working (as it is a fax connected line and I tested it)..:-)
I don't think its issue with modem, as I tried with another modem also and got the same results.
Any suggestions..?
Thank you
MS
mvsheik123 Mon, 09/29/2008 - 11:02
Nevermind. Something going on with original phone line. Tried with another phone line (which is already connected to Modem) and works fine. Thank you for reading the post.
MS
