how do you stop show tech
Answered Question
Sep 29th, 2008
How do you stop show tech COMMAND from displaying all the input w/out stoping.. I need to captur something there but it goes fast all the way to the end.. Thanks
1 vote
Correct Answer by Jon Marshall about 8 years 3 months ago
Yes you can.
After double-clicking on hyperterm.exe and giving it a name the next window to pop up is the "Connect to" window.
Go to the bottom drop down box "Connect Using" and then select "TCP/IP Winsock". You will then be able to enter the IP address of the remote device.
Jon
Overall Rating: 2.8 (7 ratings)
Jon Marshall Mon, 09/29/2008 - 11:06
Easiest way i have found is to use windows hyperterm which you can use from a console connection or a telnet connection.
Along the top of the hyperterm window there are menu options
File Edit View Call Transfer Help
Under Transfer select "Capture text" and then it will prompt for a filename. Once entered anything in the hyperterm screen will be written to this file. When finished you can go back under Transfer to select "Stop capture".
Jon
cisco steps Mon, 09/29/2008 - 11:08
Thanks Jon,
I am telneting from remote site... I did set the lenght to 24 .. that did not work.. any other input .. Thanks
Jon Marshall Mon, 09/29/2008 - 11:10
No the set length won't work with "sh tech support"
Give windows hyperterm a try if you are on a windows client. Hyperterm supports telnet so you can do it remotely.
Jon
Jon Marshall Mon, 09/29/2008 - 11:30
Are you saying you can't find hyperterm ?
Attached is a winzip file with hyperterm.exe and hyperterm.dll.
Extract to a folder and double-click hyperterm.exe to run.
Jon
cisco steps Mon, 09/29/2008 - 11:38
JON
You said
"Give windows hyperterm a try if you are on a windows client. Hyperterm supports telnet so you can do it remotely"
r u saying that I can access a device that is remotely located by using w/hyperterm.. ?
how ?
yes I do have hyperterm in my machine . the problem that there is no telnet option its all com ports
Correct Answer
Jon Marshall Mon, 09/29/2008 - 11:43
Yes you can.
Jon
jacobsamuel2021 Mon, 10/06/2008 - 05:50
If i want to brake the output of sh tech command from the console. how can i do that?
regards
dabels Tue, 10/07/2008 - 11:53
I guess the real answer here is that you can not stop the show tech. some versions of ios will allow you to show tech for specific things (enter show tech ? ) and see if there are other options that you could use depending on the information you are looking for..
you could also try the emulator putty it has a logging option as well.
andrewdennehy Wed, 10/15/2008 - 21:52
Rather than breaking the output from the device, can I suggest a workaround?
Hyperterminal (and a lot of other terminal emulators such as puTTY etc.) allows you to ceate a log of your session to a text file.
On Hypertrm do the following:
Click "Transfer -> Capture Text"
Browse to the location to create the file.(I normally just use the desktop)
Enter a filename (Something meaningful.)
On the Console, enter "show tech" and allow the device to vomit out all the data. (Vomit is the technical term for it.)
Go to Transfer -> Capture Text -> Stop
Your show tech should now be saved to the filename you selected earlier. You can open it up and manipulate the text to your hearts content, including searching and cut and pate of the interesting section.
A few notes on using the log.
I like to run a log when I have a complex issue to troubleshoot/configure. It gives you an audit trail if you make a mistake in the config and need to figure out what you did.
You can also pause and restart a log so that you only capture the interesting stuff, and not the typo's. :)
Later,
Andrew
a.hajhamad Wed, 10/15/2008 - 22:40
In addition to the posts above.
You can redirect the output of the show tech-supp to either FTP, TFTP, flash .....
for tftp:
show tech-support | redirect tftp://192.168.100.136/myrouter_tech
Or you can redirect the show tech support file to the router flash and after that you can copy it from the flash to the tftp server.
Abd Alqader
Richard Postmus Fri, 10/17/2008 - 06:29
Try a "show tech-support page", but difficult to stop once started.
Or, as noted already use the redirect and send to flash. But, then read with "more":
show tech-support | redirect flash:show-tech
more flash:show-test
