Shutdown of IDSM-2
Sep 29th, 2008
Good day,
We are scheduling Power maintenance work in the next few weeks. We will be shutting down our 6509 switches. Should we also shutdown the IDSM-2 blades in our switches??
ex: reset power down command via the CLI
Overall Rating: 4 (1 ratings)
rhermes Mon, 09/29/2008 - 13:24
  • Gold, 750 points or more
Ir you are on the IDSM module itself, you can issue a "reset powerdown".
The reset powerdown command performs a shut down but does not remove power from IDSM-2. To remove power from IDSM-2, use the set module power down module_number command from the Chassis CLI.
