Two Access Server headache
Sep 29th, 2008
Two access server problems.
1. Is an 2511-RJ, which got stocked from time to time and in an attempts to reinstall, it got hanged without accepting key strokes from the keyboard again here is the output. (9600-8-N-1)
"Would you like to enter the initial configuration dialog? [yes]:"
Please it is not a cable connection problem because it boots up whenever restarted and stays here.
2.The second is a 2511-ASYN, with the following output,
Router(boot)>
How can i get out of the output to reinstall this?.
Even after pressing CTRL+BREAK, >o/r 0x42, followed by i, the router will bring me back to the same prompt.
Please help me!!!!!!!!!!!!
Two access server for that matter cripplingly my lab activies.
amritpatek Fri, 10/03/2008 - 11:32
  • Silver, 250 points or more
You can configure the access server following one of the procedures described in the following sections
Configuring the Access Server Using the Configuration Mode
Configuring the Access Server Using AutoInstall
Configuring the Access Server Manually Using the Setup Facility
Here is the configuration guide for the the Access Server it may help you in the configuration
http://www.cisco.com/en/US/docs/routers/access/2500/software/user/guide/cnfg.html#wp4959
