PBR problems
Answered Question
Sep 29th, 2008
I'm trying to set up a PBR on my 4506 switch: (Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(31)SGA, RELEASE SOFTWARE (fc3))
But, when I'm on the interface line configuration: [swcore(config-if)] the switch doesn't accept the command "ip policy route-map IT", it appears the switch doesn't have the command.
And I just have configured the access-lis t and i'vve created the route map IT.
I think its because the IOS version.
What could be the cause?
Tauer
Correct Answer by Jon Marshall about 8 years 3 months ago
Tauer
I don't believe PBR is supported on the Sup II+ as this supervisor is really a L2 sup with only some basic L3 capabilities.
The SupIV would support PBR as it is a L2/L3 supervisor.
The difference between BASE and Enterprise is primarily enhanced L3 routing eg EIGRP/OSPF/BGP and some additional L3 functions such as PBR.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 09/29/2008 - 13:05
Tauer
Which supervisor are you running ?
Regardless i don't believe PBR is supported in the IPBASE version. You need the Enterprise version of code.
Jon
Tauer Drumond Tue, 09/30/2008 - 03:17
Hi Jon,
I'm running the Supervisor IV.
What is the diference between both...IPBASE and Enterprise?
Tauer
Correct Answer
Jon Marshall Tue, 09/30/2008 - 05:50
Tauer
Jon
limtohsoon Sat, 03/28/2009 - 19:28
Hi Jon,
I have a Catalyst 4507R with Sup V.
Platform: CAT4500-SUP5
IOS: 12.2(31)SGA4
Feat.set: ENTERPRISE SERVICES SSH
It supports the normal PBR. I'm looking for support of PBR Recursive Next Hop. Do you know if the higher version of IOS, e.g. 12.2(50)SG1, supports this feature?
Feature Navigator says it is not supported on a CAT4500 platform. But Feature Navigator can be inaccurate sometimes.
Please advise.
Thank you.
B.Rgds,
Lim TS
