Scott Fella Mon, 09/29/2008 - 18:53
4.2 and later code has the configuration in xml, prior versions is in bianary. So if you decide to downgrade to 4.2 to 4.0 then you will have to reconfigure the wlc from the startup wizard and then you can restore the wlc configuration if you had a good backup from that version.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml#t2
