ISDN keep dropping after 20 second
Sep 29th, 2008
Hi all,
I have a ISDN issue here, ISDN keep dropping after 20 second exactly, below is the debug captured during the problem:
Sep 30 00:41:19.870 GMT: BR0/3/0:1 DDR: disconnecting call
Sep 30 00:41:19.870 GMT: DDR: Dialer Watch: watch-group = 8
Sep 30 00:41:19.870 GMT: DDR: network x.x.x.x/255.255.255.255 UP,
Sep 30 00:41:19.870 GMT: DDR: primary UP
Sep 30 00:41:19.870 GMT: ISDN BR0/3/0 EVENT: UserIdle: callid 0x800D received ISDN_HANGUP (0x1)
Sep 30 00:41:19: %ISDN-6-DISCONNECT: Interface BRI0/3/0:1 disconnected from 19734103188 , call lasted 20 seconds
Sep 30 00:41:19.870 GMT: ISDN BR0/3/0 Q921: User TX -> INFO sapi=0 tei=68, ns=47 nr=48
Sep 30 00:41:19.870 GMT: ISDN BR0/3/0 Q931: DISCONNECT pd = 8 callref = 0x0D
Cause i = 0x8090 - Normal call clearing
Suspect it could be local telco issue, however, telco already feedback that their side is clean, please kindly advise.
Router#sh isdn his
ISDN CALL HISTORY
Call History contains all active calls, and a maximum of 100 inactive calls.
Inactive call data will be retained for a maximum of 15 minutes.
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out ---N/A--- +2222222222 20 0
Thank you,
Danilo Dy Mon, 09/29/2008 - 17:40
  • Blue, 1500 points or more
Thus your ISDN port a U interface and you are using a straight-through cable? It may sound strange but try using RJ11 telephone cable :)
