Cisco 877 / QoS
Answered Question
Sep 30th, 2008
Hi Folks,
I have a question about my Cisco 877, I am running "c870-advsecurityk9-mz.124-20.T1" but when I try to set-up QoS under SDM it says I am running the wrong IOS. Also under Firewall and ACL I am not able to set-up any P2P protection (again it says I am running the wrong IOS).
Question is, which IOS supports these features?
Cheers.
M
Correct Answer by Jon Marshall about 8 years 8 months ago
M
For QOS support you need either Advanced IP Services or Advanced Enterprise - see attached Q&A table, about 1/4 of the way down under "General Software Features"
http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/prod_qas0900aecd8028a982.html
Not too sure about the P2P protection - do you mean DMVPN or GETVPN ?
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 09/30/2008 - 01:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
M
Jon
mdujardin Tue, 09/30/2008 - 01:28
Hi Jon,
Thanks mate, that table was exactly the type of thing I was looking for (never easy finding anything on the Cisco site).
For P2P protection, I will see if it's included in this image and let you know.
Thanks for the speedy reply.
M
mdujardin Tue, 09/30/2008 - 02:22
Jon,
That image worked fine foe P2P protection. I can now block bittorrent etc.
Have a good day mate.
M
