IOS SLB - Vserver always UP
Sep 30th, 2008
Hi guys.. i have this situation with IOS SLB. Theres a virtual server and 2 real servers. The traffit to be balanced runs in a UDP port. We are using a basic ping probe to monitor the real servers. The thing is that even if the probes fails, the Vserver remains "operational", so it is advertised to our network (we are redistributing the static route that points to the null0 int).
We would think that if the real servers are down, the vserver should be also down, as well as the static route.
Here are the configs:
ip slb serverfarm XXX
nat server
predictor leastconns
  real 1.1.1.1
reassign 2
faildetect numconns 4
retry 20
inservice
  real 1.1.1.2
reassign 2
retry 20
inservice
ip slb vserver YYY
  virtual 10.10.10.10 udp 9020
  serverfarm XXX
  idle 120
  delay 5
  inservice standby SERVER
  exit
Any ideas of why the Vserver remains always up?
PS: we already tried disabling the automatic failure detection (no faildetect inservice).
thanks in advance!
Overall Rating: 1 (1 ratings)
omarmontes Tue, 09/30/2008 - 01:01
by the way.. when issuing the "show ip slb reals", the real servers are in the "PROBE_FAILED" status, and as I mentioned before, the vserver is in the operational status.
sachinga.hcl Tue, 09/30/2008 - 16:49
show module csm 3 vservers detail
If the CSM cannot determine the port, the probe is not enabled.
send me the output of the detail of the probe :
sho mod csm 4 probe name probe_name detail
change the values in the above command according to your configuration.
If your probe has a status of ???. This is because the CSM failed to determine the destination port to use for sending the probes.
When the probe fails to run (indicated by a status of ???), the real server remains operational.
send me output of
sho mod csm 4 real
Hope I can troubleshoot this for you.
Thanks and regards,
Sachin Garg
Senior Specialist Security
HCL Comnet Ltd.
A-10, Sector 3, Noida- 201301
Mob: 9911757733
Email: [email protected]
omarmontes Tue, 09/30/2008 - 20:24
We are using IOS-SLB. So there is no module. But we just found the answer to our problem. We issued the "advertise active" command in the vserver configuration, so it installs the route to the null interface only if at least one of the real servers is up.
Thanks for the time!
