Jon Marshall Tue, 09/30/2008 - 01:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Would help if you included some more details re. supervisor/IOS version but in general yes you can configure PBR under a L3 vlan interface.
Jon
sumitsharma Tue, 09/30/2008 - 04:20
Thanks Jon, can you tell any URL which is having a example of this. Well in this case I m assuming sup 720 in 6500 along with any IOS Image which are currently available
Jon Marshall Tue, 09/30/2008 - 05:24
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
2 links.
1) This has some info about PBR on the 6500, what is supported and what is done in hardware as opposed to software. Have a read and make sure you understand that any PBR that is processed in software will have a greater impact on your 6500
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/layer3.html
2) Configuring PBR - this link is cross referenced in the 6500 documentation
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr.html
Jon
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
deleted
