NAT for two ISP links
Sep 30th, 2008
How can we work out the following senario
One router with two serial links from two different ISPs for redundancy. The hosts in lan and a mail server needs NAT at the router end. How to configure nat for the LAN and mail server with the two serial links which has two different sets of IP ranges?
mohamedsafeer Tue, 09/30/2008 - 20:59
Hi calin
Thanks for the document.
i would like to have only failover and load-balancing is not required. Based on your document i understand its done through policy map.. will need to explore the options and let you know the details.
