Config import after upgrade: How long should I wait?
Sep 30th, 2008
Hi folks
I've been trying a MARS 50 same-appliance migration a few times now and always get stuck at the same point. Config import gives me the message "Updating data package, may take half hour or longer ..." and then nothing happens, this time I've been waiting for almost two hours. A sysstatus show Java taking up around 98% CPU, thats all I can see.
Anyone has anything experience with this scenario?
Overall Rating: 1 (1 ratings)
bwilmoth Mon, 10/06/2008 - 08:27
Use the pnimp import config [remote-path] command to import configuration data into the target appliance, whether that appliance model equivalent to or greater than the model of the source appliance.
The following URL explains about Same Appliance Data Migration Work Flow:
hoffa2000 Mon, 10/06/2008 - 12:06
Yes, thank you, I already know that. My question was wether someone has had the same problem as I.
