NAT is not working - Help
Answered Question
Sep 30th, 2008
Hi all
When I connect to the switch on my cisco 877w i get an ip address but when I try browse out I am not getting natted. can you tell me why plesae?
HQADSL#sh run
Building configuration...
Current configuration : 3182 bytes
version 12.4
no service pad
service password-encryption
hostname HQADSL
boot-start-marker
boot-end-marker
logging buffered 4096 warnings
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool dhcp-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 159.134.237.6
domain-name telnet
lease 0 2
ip name-server 159.134.237.6
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 key 1 size 128bit 7 9177AE420031ACF9A58EA67B29DF transmit-key
encryption vlan 1 mode wep mandatory
ssid quattro
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description Internal LAN
no ip address
bridge-group 1
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname user
ppp chap password password
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip access-list extended telnet
permit tcp host 1.2.3.4 any eq telnet log
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^CCC
*** WARNING ***
This system is private and may be acccessed only by
authorized users. The system owner reserves the right
to monitor any and all activity taking place on this
system and any attempts to connect to it. Unauthorized
users or users who exceed (or attempt to exceed), their
authorized level of access are subject to prosecution under
any local or international laws that apply as well as Company
initiated proceedings.
^C
line con 0
no modem enable
line aux 0
line vty 0 4
access-class telnet in
password xxxxxxxxxxxxxx
login local
transport input telnet ssh
scheduler max-task-time 5000
end
HQADSL#
Correct Answer by Danilo Dy about 8 years 8 months ago
You have NAT configured for ACL 101, however, your ACL 101 is missing.
Try adding this..
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
Overall Rating: 5 (1 ratings)
Correct Answer
Danilo Dy Tue, 09/30/2008 - 03:03
  • Blue, 1500 points or more
Try adding this..
darkbeatzz Tue, 09/30/2008 - 03:11
I just added an extended access-list 101 - permit ip any any and lost connectivity!! having router rebooted at the moment. why would this have happened? is this all it requires to get working?
Danilo Dy Tue, 09/30/2008 - 03:13
I will not recommend "any any" use the ACL I provided.
