Site to Site VPN 1841 to Linux
Sep 30th, 2008
Hi i am trying to implement a site to site VPN on a 1841 to a linux Debian.
I can get the VPN to work but no traffic is going into the tunnel. Please help i have attached a copy of the config.
mchin345 Mon, 10/06/2008 - 11:01
Use the ping command to check the network or find whether the application server is reachable from your network. It can be a problem with the maximum segment size (MSS) for transient packets that traverse a router or PIX/ASA device, specifically TCP segments with the SYN bit set.
You are unable to initiate the VPN tunnel from ASA/PIX interface, and after the tunnel establishment, the remote end/VPN Client is unable to ping the inside interface of ASA/PIX on the VPN tunnel. For example, the pn client can be unable to initiate a SSH or HTTP connection to ASA's inside interface over VPN tunnel.
