Enabling SNMPv3 on 2960 and LMS2.6
Joe Clarke Tue, 09/30/2008 - 06:48
Actually, unless you want to filter out certain OIDs, you should use the built-in v1default view:
snmp-server group v2group v3 auth write v1default
This will grant your group access to all the objects community string-based SNMP would.
Since this is a switch, you will also need to enable SNMPv3 contexts so that Campus Manager can poll VLAN data. Run "show snmp context", then add a line such as the following for each context:
snmp-server group v3group v3 auth context CONTEXT
Thank you for this info. The LMS recognized the 2960 switch.
If I would be implementing this to the core switch "show snmp context" would be equivalent to what command?
I have the following:
C6509E#show snmp ?
mib
engineID show local and remote SNMP engine IDs
group show SNMPv3 groups
pending snmp manager pending requests
sessions snmp manager sessions
user show SNMPv3 users
| Output modifiers
6509E.221#
Would this be equivalent to the MIB?
Joe Clarke Thu, 10/02/2008 - 21:54
The code running on this switch does not support SNMPv3 contexts. You need to upgrade to recent 12.2(18)SFX code ( or later).
Joe Clarke Fri, 10/03/2008 - 06:47
No. If your code/device does not support SNMPv3 contexts, then you will have to stick with v1/v2c in order for Campus Manager to be able to fully manage the device. Upgrades are available for all switches that support SNMPv3 except the 2950 series. Those switches will never support SNMPv3 contexts.
