ASA websense, check primary server, then secondary
Sep 30th, 2008
We have websense for our url filtering,
Can ASA 5510 be set up to check a primary server, then if that is not available, to check the secondary.
Will the ASA check from top down?
url-server (inside) vendor websense host Websense timeout 10 protocol UDP version 4
url-server (inside) vendor websense2 host Websense timeout 10 protocol UDP version 4
filter url except 10.250.0.0 255.255.0.0 0.0.0.0 0.0.0.0 allow
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
filter url 443 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
Overall Rating: 5 (2 ratings)
suschoud Tue, 09/30/2008 - 05:29
Yes,
You can identify up to four filtering servers per context. The security appliance uses the servers in order until a server responds. You can only configure a single type of server (Websense or Secure Computing SmartFilter ) in your configuration.
ASA-5510-8x(config)# url-server (inside) vendor websense host 1.1.1.1
ASA-5510-8x(config)# url-server (inside) vendor websense host 1.1.1.2
Do rate helpful posts.
Sushil
wilson_1234_2 Tue, 09/30/2008 - 06:17
Thanks for the reply,
Oops, I had it incorrect, it should be like this right?:
name 10.1.1.1 Websense
name 10.1.1.2 Websense2
url-server (inside) vendor websense host Websense2 timeout 10 protocol UDP version 4
wilson_1234_2 Mon, 10/06/2008 - 10:49
Since implementing this I am getting the "url server not responding" every five seconds.
Can I adjust this to something like having the ASA check every two minutes?
