CSM 3.2.1, AIP-SSM10, Change local accounts
didyap Mon, 10/06/2008 - 08:59
  • Silver, 250 points or more
To use Security Manager, users must log into the product. Create individual accounts for each user. You can either create accounts that are unique to Security Manager, which are defined on the Security Manager server and are called local accounts, or you can use your enterprise ACS server to authenticate users
For the further description and details following URL may help you ;
http://www.cisco.com/en/US/docs/security/security_management/cisco_security_manager/security_manager/3.2.1/user/guide/aduser.html#wp900654
mdreelan Tue, 10/07/2008 - 07:24
I dont see a way to do this either. And I would like to make similiar chages on both AIM-IPS-K9 and AIM-SSM-10!
