Anyone knows what this message/error means?
Sep 30th, 2008
  • Silver, 250 points or more
C3640#
Sep 30 14:33:18.269: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=649388EC, count=0
-Traceback= 6039EC38 60423D08 605EF4F4 605EF720 625438D8 62544C64 6255F0A0 625509C4 625500B4
Sep 30 14:33:18.293: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=64938C18, count=0
Sep 30 14:33:18.393: %SYS-2-BADSHARE: Bad
refcount in datagram_done, ptr=64938F44, count=0
I keep seeing these messages on my Cisco 3640 router running IOS version c3640-jk9o3s-mz.123-8.T11.bin.
Danilo Dy Tue, 09/30/2008 - 07:05
  • Blue, 1500 points or more
Are you running IGMP? Turn it off "no ip igmp snooping" in global coonfiguration mode.
If that doesn't fix it, update your IOS image.
cisco24x7 Tue, 09/30/2008 - 07:10
How do you know that it is igmp related?
The image is the latest 12.3(T) I can fit on a
Cisco 3640 router. I don't think I can upgrade
to a later IOS image.
Any more ideas? Thanks.
Danilo Dy Tue, 09/30/2008 - 07:14
Have you tried the commands yet?
According to Cisco, this error is cosmetic (or informational only) and should not affect the performance.
cisco24x7 Tue, 09/30/2008 - 07:25
I am not running igmp on this router. Thanks.
cisco24x7 Tue, 09/30/2008 - 07:33
I have a L2L VPN between this router and another Cisco 3845 router. When I do this:
ping 129.174.100.1 source lo0 repeat 99999999 size 2048 (129.174.100.1 is the IP address
of the network behind the other VPN router),
I start seeing A LOT of this:
Sep 30 15:26:16.600: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=64939F20, count=0
Sep 30 15:26:16.688: %SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=6493A24C, count=0
C3640#
CPU on the router goes from 0% to almost 90%.
Must be an IOS bug.
Danilo Dy Tue, 09/30/2008 - 07:40
A lot of caveats similar to this message but not specifically for 3640 and IOS and exact message.
Here are the lists of possible problems
- IGMP
- MLPPP
- GRE
- VoIP
- DMVPN
- ADSL
- IOS
Most of them no workaround (specially DMVPN). All of them are known bugs, but you mentioned that you can't update your IOS image.
[EDIT] If you want to search them, search "%SYS-2-BADSHARE: Bad refcount in datagram_done" and also look for "Traceback" in the results. Without "datagram_done" the search may direct you to hardware problem.
