MPLS TE: Non revertive FRR implementation
javiercastro
I have the following issue regarding a Fastreroute link protection implementation using IOS XR.
The desired network behavior is that once a link failure is fixed the protected traffic keeps flowing through the backup path until it is manually switched to the primary path.
I have been advised that this behavior can be achieved using a second path option under the primary tunnel configuration, actually it should be a dynamic path. Something like this:
interface tunnel-te100
ipv4 unnumbered Loopback0
signalled-bandwidth 5000000
destination X.X.X.X
fast-reroute
path-option 1 explicit name primary_path
path-option 10 dynamic
Does anybody knows if configuring the last command (path-option 10 dynamic) would affect the default FRR behavior? (making it like non revertive)
Calin C.
Level 5
Level 5
Hello!
You are using IOS XR, and I haven't had the chance to work with it, so I don't know the behavior. I can tell you what is the behavior with my config under regular IOS:
interface Tunnel21
ip unnumbered Loopback0
tunnel destination 172.30.32.1
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng fast-reroute
tunnel mpls traffic-eng priority 2 2
tunnel mpls traffic-eng bandwidth 158
tunnel mpls traffic-eng path-option 1 explicit name low-klu
tunnel mpls traffic-eng path-option 10 dynamic
When the explicit path fails, the dynamic one is follow up. After the explicit path recover, the traffic is taking the primary path.
Sorry if this is not what you expected!
Cheers,
Calin
Then, the same configuration I am want to use on IOS XR doesn't behave the way I want on IOS. Is there any chance this behavior could be different using IOS XR??
