CCX5 - Scripts, prompts (paths)
Answered Question
Sep 30th, 2008
Hi!
I've recorded a prompt and have saved it under c:\Program Files\wfavvid\Prompts\user
Now I'm creating a script that will use that prompt. It is saved under c:\Program Files\wfavvid. When I'm defining the prompt variable at the script what path should I use in the value field?
Ana
Correct Answer by Chris Deren about 8 years 8 months ago
I would suggest uploading the prompt to the prompt repository and then simply using the Browse button to locate it. If you upload it to the default location (depending on what you selected as default during the install) and you can simply reference P[promptname.wav].
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Tue, 09/30/2008 - 13:31
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
