09-30-2008 08:31 AM
Can anyone tell me whether rel.6.0 of MARS Local Controller will allow me to use my own CA-generated SSL certificates ? I'd like to use (and it's also company policy) a trusted CA for server certificates. I know it can't be done on rel.4.3.
Joe
10-06-2008 10:42 AM
To support the certificate management features in MARS, the following system inspection rule exists:
System Rule: CS-MARS Failure Saving Certificates/Fingerprints. This inspection rule indicates that MARS has failed to save a new or changed device SSL certificate or SSH key fingerprint based on either explicit user action or automatic accept as specified on the SSL/SSH Settings page.
In addition, the following reports appear under the System: CS-MARS Issue category.
Activity: CS-MARS Accepted New Certificates/Fingerprints
Activity: CS-MARS Accepted Conflicting Certificates/Fingerprints
Activity: CS-MARS Detected Conflicting Certificates/Fingerprints
Activity: CS-MARS Accepted New Certificates/Fingerprints'
Activity: CS-MARS Failure Saving Certificates/Fingerprints
Activity: CS-MARS Device Connectivity Errors
10-07-2008 05:27 AM
I don't think so, the most you can do is generate a new self-signed cert. doh! just noticed you said 6.x. You can't do it in 5.x. The most I can say about 6.x is that I've not seen anything documented about being able to do it.
