pnexp failing silently
I'm using SFTP (free FTPd on WinXP) to export the config for an upgrade to 6.0. When I run an export, the appliance connects, builds a few directories, claims it was successful with the export and finishes. Looking at the directory structure of the SFTP server, however, there are directories created but no files created where the config could have been saved.
Any ideas?
If NFS is a better route, could someone suggest a decent free NFS server for WinXP.
Anonymous (not verified) Mon, 10/06/2008 - 10:47
This issue only happens when sending logs to the root "/" directory of the sftp server. If the logs are sent to a subdirectory "/tmp" then all files are transferred correctly.
Specify full directory name from root path, example /home/myuser/mydirectory
