bgp_ifachange_group
Sep 30th, 2008
Team, In my logs im getting this error over and over. Does anyone know whats going on here?
The circuit is frame relay
Here is the entire log error:
bgp_ifachange_group: Notification sent to 10.x.x.x external AS 6xxxx code 6 (cease) subcode 6 (other configuration change)Reason: Interface change for peer group
milan.kulik Wed, 10/01/2008 - 04:16
are you sure this is a complete syslog message?
IMHO, it should start with %BGP-x-...
where x is a severity.
You could paste it into the CCO Error Message Decoder tool to anaylze.
It looks to me like some "SNMP trap sent" message, possibly?
BR,
Milan
wesley.roberts Wed, 10/01/2008 - 04:57
Yes, I copied it straight from the router log. Im pretty sure thats the entire thing.
I am going to look into the "CCO Error Message Decoder tool " you speak of and paste the answer here.
Kind Regrads
Kyle
milan.kulik Wed, 10/01/2008 - 05:27
It will not work, I'm afraid.
Requires %BGP... or %STP.. ,etc. in the mesage beginning.
And it's really how syslog messages usually look like:
"Sep 15 10:26:05: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up", e.g.
BR,
Milan
Danilo Dy Wed, 10/01/2008 - 07:02
Looks like the logs of juniper :). The logs tells something happens in the link between the local BGP speaker and its remote peer (maybe the link went down, congested, unavailable?).
Harold Ritter Thu, 10/02/2008 - 11:59
Danilo,
You are correct. This log message comes from a JUNOS box and it reveals that there was a problem with the link between the two peers.
