IP Default-gateway
Sep 30th, 2008
How get configured IP default gateway on router
Jon Marshall Tue, 09/30/2008 - 10:46
You would simply use this commmand from global config mode
router(config)# ip default-gateway
Note that you would only do this on a router if you have ip routing disabled. If your router is acting as a router then you need to look into the ip default-network command or the ip route command. See this link for more details
medusindsol Tue, 09/30/2008 - 12:49
Hi Jon,
thanks for your response. I already configured ip default gateway on interface, but want to see on to router thru show command. Thanks.
Giuseppe Larosa Tue, 09/30/2008 - 10:48
ip route x.x.x.x
where x.x.x.x is the ip address of the IP next-hop default gateway
this requires that ipv4 routing is turned on with
ip routing
if ip routing is disabled like in a L2 switch
ip default-gateway x.x.x.x
Hope to help
MUHAMMAD SHAHEEN Fri, 10/03/2008 - 02:39
Hi Anand,
Yes, You can check IP default-gatway on the L3 Switch/Router by using the following command.
#Show ip route
hope this helps !!!
