Router Dead
Sep 30th, 2008
Hi Folks,
I've got an 877 and by mistake I delete all files in flash. After a power cycle the router is dead and I can't get in (not tried console cable yet) - if I console in what is the best command to reset it back to factory reset?
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 09/30/2008 - 10:50
If you have deleted all files in flash there is a good chance you now have no IOS to boot the router with so you need to do more than set it back to factory reset. You will need to get another image into flash. Have a look at this link which gives a recovery procedure. You will need to be consoled in
mdujardin Tue, 09/30/2008 - 10:55
Thanks Jon, just looking at the document now. Seems to be exactly what I need.
No more problems today! Promise :)
Jon Marshall Tue, 09/30/2008 - 10:58
"No more problems today! Promise :)"
No problem, that's what NetPro is for after all :-)
