3560QoS and "Service-Policy Input"
Sep 30th, 2008
Hi Group,
I am trying to use the following QoS policy on Catalyst 3560 (more details attached):
class Voice_Media
set ip dscp 46
police 256000 16000 exceed-action drop
class Nortel_Voice_Signaling
set ip dscp 40
police 32000 8000 exceed-action policed-dscp-transmit
class Cisco_Voice_Signaling
set ip dscp 24
class Security_Camera_Video_Stream
set ip dscp 34
police 500000 16000 exceed-action policed-dscp-transmit
class VTC_Video_Conferencing
set ip dscp 36
police 384000 8000 exceed-action policed-dscp-transmit
class Business_Applications
set ip dscp 26
police 20000000 32000 exceed-action policed-dscp-transmit
class Bulk_Data
set ip dscp 10
police 5000000 8000 exceed-action policed-dscp-transmit
class Scavenger
set ip dscp 8
class class-default
set ip dscp 0
police 5000000 8000 exceed-action drop
However, when I try to apply the QoS Policy "IPPHONE_WITH_USERPC" it takes my command but it doesn't apply it in the show run:
interface GigabitEthernet0/2
switchport access vlan 4
switchport voice vlan 44
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 30 0 0 0
priority-queue out
mls qos trust cos
spanning-tree portfast
Can anyone assist me here?
I am using 12.2(35)SE:
Cisco IOS Software, C3560E Software (C3560E-UNIVERSAL-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 17:18 by nachen
Image text-base: 0x00003000, data-base: 0x01600000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(35r)SE1, RELEASE SOFTWARE (fc2)
ojrpva-s999n-f14 uptime is 14 weeks, 1 day, 4 hours, 15 minutes
System image file is "flash:c3560e-universal-mz.122-35.SE5/c3560e-universal-mz.122-35.SE5.bin"
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C3560E-24PD (PowerPC405) processor (revision E0) with 122880K/8184K bytes of memory.
Processor board ID FDO1144V07H
Last reset from power-on
5 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1E:13:D0:93:00
Motherboard assembly number : 73-10318-11
Motherboard serial number : FDO1142073K
Model revision number : E0
Motherboard revision number : B0
Model number : WS-C3560E-24PD-S
Daughterboard assembly number : 800-28590-01
Daughterboard serial number : FDO11320CKJ
System serial number : FDO1144V07H
Top Assembly Part Number : 800-27549-01
Top Assembly Revision Number : C0
Version ID : V01
CLEI Code Number : COM7F10ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 30 WS-C3560E-24PD 12.2(35)SE5 C3560E-UNIVERSAL-M
Configuration register is 0xF
Thanks in advance...
- Kashif
Overall Rating: 5 (1 ratings)
schmij01 Wed, 10/01/2008 - 05:22
You can't apply a trust statement and a policy map to an interface* so I would remove the trust cos statement and then try the service policy statement.
* You can in 12.2.40SE, but the trust statement only applies to traffic not matching the policy map. If you want this behavior, upgrade to that release or later.
