Acs exp. selection rules
Sep 30th, 2008
Have anyone experience about the selection rule?
My problem is:
I've two policy against the same group device:
One use active dir database and PEAP method and the second use local database and eap fast (wifi phone)
How I can discriminate the authentication because if I connect in peap and the first polici is for peap work fine but the wifi phone does not work.
If I put the first policy for eap-fast the wifi phone work fine but the peap device doesn'work.
I think that the problem is to identify the correct attribute but I'm not able to do.
thanks a lot
Premdeep Banga Tue, 09/30/2008 - 13:56
You may want to use the Network Access Profile (NAP) feature on ACS, which was introduced starting from version 4.0
Please rate if it helps!
ggozzi Wed, 10/01/2008 - 00:23
Thanks for the answer;
but I have not an ACS 4.0
I've an ACS express appliance 5.0 without NAP
Any suggestions?
Trending Topics - Security & Network
