Event ID: 428 on Unity 4.2
Sep 30th, 2008
  • Bronze, 100 points or more
I have a distributed Unity topology which are digitally networked. The unitys are located in Calif, NewJersey, and London.
The London Unity consistently get the error below...so I look up the ext and it belongs to a the NJ unity which is a valid acct. I later find there is another user with the same ext attach to the Calif Unity. However, I cannot delete this acct.
So I go to "Sub Bulk Delete" in each unity to try to delete and it cannot find this ghost acct.
Event Type: Error
Event Source: CiscoUnity_PHGreeting
Event Category: Error
Event ID: 428
Date: 2008/09/30
Time: 16:37:33
User: N/A
Computer: UNITY2
Description:
Handler [rrussell] is using an extenstion [8626] that is being used by another handler on line 2506 in file E:\Views\CU4.2.0.110\un_Conv1\Scripted\ConvSub\PHGreeting.cpp
aamercado Tue, 09/30/2008 - 21:14
nevermind..tac found a bug and had me upgrade to a ES version. Thx
