Managing a PIX using VPN Client.
Sep 30th, 2008
Is it possible to connect to PIX using VPN Client and access ASDM and SSH?
I have to manage a remote PIX and I was thing in using a Remote Access VPN to do that.
I have implemented the VPN successfully but I can't access the ASDM.
Paulo Roque
Matthew Warrick Tue, 09/30/2008 - 20:38
Without seeing the config you will need:
asdm image disk0:/asdm-image.bin
http server enable
http vpnpoolnetwork netmask inside
I think that just about covers it.
Farrukh Haroon Wed, 10/08/2008 - 23:44
You would also required the following command if you want to access to inside interface from the outside:
management-access inside
Please rate if helpful.
